I have a 94(?) Max IV with a B&S Vanguard 18hp engine (model 350447). I'm slowly learning about small engines with this machine, but have a long way to go. So thank you for your patience.
This summer (and previous winters) I've had it running fine. But with the recent cold weather, now it will not start. I've replaced the fuel filter. I've also pulled apart the carburetor and sprayed out the jets -- at least, as many as I could see without completely removing the carb from the engine block. I did notice that the carb body's cardboard gasket was "torn" in one place (it's not a "nick" -- there's no material missing -- but the layers of cardboard have separated in one place).
If I pour a bit of gas into the carburetor directly (down past the open choke valve), I can pull-start it and it will run solidly for several seconds until the gas burns off.
So, a few questions:
1. Is the damaged gasket the cause of my problem, or a red herring? (Seems like it might still provide a good seal when everything is bolted together tightly, but I dunno'. The rebuild kit that I've found costs over $200 because I have an old carb model)
2. Does the fact that the engine runs on "direct-fed gas" eliminate any carburetor-related issues?
3. Might it be a bad fuel pump, and if so, what part should I replace it with? (Right now its fitted with a square metallic "Minuki" pump, co-branded with the B&S diamond logo. I assume it's an original part. No model number that I can see.)
I've seen other threads here where people found issues with old/disintegrating fuel lines. And bad vents on their gas tank cap. I'll investigate those issues as well.
I have to hike a long distance, in the snow, carrying my tools, to get to my machine, so I'm hoping to collect some good troubleshooting tips and bring whatever parts I need before I make the long journey.
Thanks in advance.
Thanks in advance.
