I have a problem with my starter. It runs in reverse. Thats with the positive hooked to the positive and ground to ground. Im bench testing it. The pinion gear doesnt come out when activated. When I switch polarities. + of battery to housing and - to the positive lead. It works the way its designed. I had the end piece with the brushes off and of course all the brushes popped out of their places and I had to put them back. I would think that the order that the brushes are now wouldnt be the cause of this. You think that if I had the brushes in different places that this may be the problem? I placed them according to the length of each brushes wire as to where they should go. Is there a set sequence for each brush? If so, anyone have a picture? Finding a wiring diagram for the routing of the brushes inside the end cap seems to be impossible.
Weird Starter Problem
Assuming your double checked your battery connections? Not sure how that motor is exactly but could it be possible to put the armature in the housing backwards? To do that the end plates would have to be able to swap sides on the round housing with the magnets? If so I think the magnets N-S would be backwards.
Ill look into your suggestion. I did take the armature out of the housing and when I put it back. I looked at it before assembly and couldn't tell which way was which. I didnt think it would matter. Another note on this starter. The pinion gear teeth were slightly worn on the very tips. So when I had it apart. I flipped the gear around. Still works exactly as it was designed. I know the gear replacement is only about 6 bucks. But when you add in shipping and tax for a new gear. Its cheaper to do it this way. Ill apply what you suggest and post the results.
LarryW, you were correct. I had the housing reversed. Thank you for that. I was running out of hair to pull.Originally posted by LarryW View PostAssuming your double checked your battery connections? Not sure how that motor is exactly but could it be possible to put the armature in the housing backwards? To do that the end plates would have to be able to swap sides on the round housing with the magnets? If so I think the magnets N-S would be backwards.
