Went on a ride today with some other folks.  Met up in elevation a bit.  When I unloaded I was amazed at how much the elevation totally wrecked my power.
After meeting up with the others we discovered that I was firing on only one cylinder. Uh, I mean my machine was firing on only one cylinder.
These engines are known to drop a push rod - dang I think - but usually the front cylinder (apparently) and mine was the back. Tim pulled the spark plug wire and I didn't here any snap. I reached in, wiggled this and that, pulled the wire from the plug a ways - there was easily a 3/8 inch gap -with no spark and then suddenly there was. We watched the spark for a bit, pushed the wire on, and ran up the RPMs.
Ran great the rest of the day.
Any ideas?
[Edit a day later]
Okay, apparently this is not an obvious thing. If it were a car I would suspect a broken conductor in the plug wire. This one doesn't look like something that is easily changed out. (but then I haven't pulled out the shop light and really given it a look see) I don't think these engines use a point system and I also don't think this engine uses electronic ignition. How does the ignition system on this engine work?
I haven't experienced the fault since.
Any ideas?
[Edit a day later]
