muffler options on kohler 20 hp
  • Tomo
    replied
    hi ,
    Using an original muffler stores a great deal of heat .
    This is very evident if u use the box /cylinder type that installs across both cylinder heads . kohler or vanguard engines etc
    If at all possible run an inline muffler in the direction of air flow coming of the cyllinder heads . All the exhaust heat exits .
    The other is to place a 2 into 1 exhaust into a muffler [prefer with spark arrestor ]
    and allow pipe work to exit body .
    The above has been used on a friends argo with great succes
    I shifted the box muffler inside body to a cylinder muffler located between the wheels outside the body on a swamp fox with great results
    Suggest that u download some of the pics that r on this site and have fabricated at a exhaust shop .The short pipes from the clinder head can be cut off the original set up and reused .
    tomo
  • Uneedthis2
    replied
    If heat is a problem do what streetbikes do. They sell material that basically blocks heat. I put it all over the back of my bike fairings because my aftermarket pipe was causing them to melt. Worked like a champ!
  • Mike
    replied
    If the excess heat is your problem then just get some header wrap and insulate your existing muffler and exhaust pipe with it. That would reduce the temperatures greatly and keep you from fabricating anything else.
  • clevernickname
    replied
    well, you can buy an exhaust tube flare tool, and use exhaust clamps. You flare one end of the pipe, slip the flare over the existing, and clamp it. It still requires cutting, but you may be able to do it that way.
  • wildbill335
    replied
    Because Its on my Argo and it sits right under the hood which is causing it to melt I want to exhost it out of the origional spot. Its not that I dont want to weld I just dont know how plan B is to go with the flex pipe and just replace it every year.
  • Mike
    replied
    Originally posted by wildbill335 View Post
    So no one uses a muffler on their engine
    I think the problem is that you posted that you don't want to weld anything. If you are going to build something yourself then you need to weld the exhaust or at least weld flanges to the header. Why not just stick with a stock exhaust?
  • wildbill335
    replied
    Thanks I have the muffler its the pipe i need to figure out
  • smog
    replied
    kohler 20 muffler | eBay
  • wildbill335
    replied
  • wildbill335
    started a topic muffler options on kohler 20 hp
    I have used flex pipe on cars for a quick repair works ok except I only get 3 or 4 months tops out of it. My question is how does it hold up on an aatv. I want to use black pipe but can not figure out how attach it to engine I cant weld anyone have any ideas I'm running a kohler 20 hp
