kohler 440 2 stroke coils
  • kohler 440 2 stroke coils
    so I bout 2 coils to replace mine,lost spark on the right lung. Can anybody tell me the correct wiring for the coils?!?!?
    thanks once again guys
    Pg 16,17 & 18
    Depends what ignition system you have.
      Originally posted by bazoo guy View Post
      pg 16,17 & 18
      depends what ignition system you have.
      404 Not Found
      :d
      thank you !!!!!!!!!!!!!! It is the k4402ax thanks again
        Hello,
        Coils most always have two terminals. The one marked positive (+) goes to 12 volts and the negative (-) goes to your ignition side like your points or module.
        Good luck.
          This engine has a magneto primary and 2 secondary coils.
          The wiring is different if it has manual or electric start and the type of keyswitch or if the lights have a separate switch.
          The manual describes the different types of systems.
