I'm rebuilding my jlo 440 & my brain can't remember removing the old seal. when installing the new one does the flat side go in facing the crank or does the cup side with spring ? also some say use thread seal & some say high temp gasket seal to bond engine togeather any coments??  Thanks!!
Help! JLO Crank Shaft Seal PTO Side
All it says in the manual is "place the oil seal on pto end of shaft flush with the casting" Pg30/31
I would assume the spring and lip is on the inside.
Is the original seal the same as the new one?
Here's the manual look at pg36 spring looks to be inside on the twin cylinder.
I think now the cup with the spring is to the outside & the starter ring fits in that cup & I do see a small lip or bevel on the flat side that may fit just inside the crankshaft bearing. yes it is the same as the old. someone will know for sure.Thanks!
