Hi, so I have an 84 argo with the Kohler twin 17 series II engine. I have replaced the condenser, cleaned and rebuilt the carburetor, cleaned the fuel tank, replaced fuel lines and filter, and rebuilt one of the brake master cylinder and calipers. I can go out and close the choke, start it up, open the choke as normal once warmed up and drive away. After say 45 minutes or so, it starts to act up. As you try to give throttle the argo sputters and goes nuts, almost wants to cut off. When you try to turn it, it really bogs down. I can stop the argo and try slowly to give throttle, it may move with no trouble and sometimes not. Also when I was backing the argo into my shelter on my ramp it stopped half way up, I gave it more and more gas.....didn't move. Finally it took hold and almost made my son and myself do a face plant into the front of the argo. I was wondering if the drive belt could be something I should check. Anyway this problem only seems to show up when I'm driving a while so I don't know if this heat related or not. Any help would be great! Thanks. By the way loving the forum......very helpful!
Cheers
Cheers
