What do I use to lube my non heated throttle cable?
Throttle Cable
There are products made that say throttle cable lube. I suggest going to a quad or motorcycle shop and getting a kit the comes with a can of lube and a clamp on tool that goes on the cable and has a hole to accept the little red straw thing. The tool forces the lube down the cable and will force any water out the other end once the case is filled with lube.l like to buy stuff and no I don't do payments!
There was a thread that discussed using antifreeze for lube. The poster claimed that it (obviously) prevented freeze-up as well. My cable froze and I tried the antifreeze trick. It worked. You might want to try it. Kind of kills two birds with one stone.
