I just picked up a project Max II with a JLO 295. I have two fuel lines running from the tank to the back. One of the lines has the fuel filter inline, so I assume this is the supply. I would assume the other is a return. Where does the return go? I see a fuel vent fitting on the carb and some other fitting just below the carb base plate. Unsure where I should connect the return?
Update
I didn't see the vac fitting on the carb...I think I'm good...
Update
