IMG_1164.jpgIMG_1161.jpgI have a real tough one for the engine guru's out there.
I finally got the Kohler 40 horse for my bigfoot project rebuilt and back together.
I tried to start it and it wouldn't build compression or pump air. Sooooo, out comes the motor, and the side cover comes back off to make sure I wasn't a tooth off on the cam to crank allignment. To try and keep this short I'll spare the details of how many hours I spent today trying to figure this out. Basicly, with the marks aligned, The intake valve stays open too long. I tried shifting the cam gear off the mark and the piston will hit valve. And yes it has good compression with the rocker arms removed.
The model# is ch1000, and the history on it is: at about 120 hours of use the p.o. let it overheat. Thats when I got it. The cylinders were worn and it needed to be bored to .020" over and new pistons. Everything else looked good. The current working theory is the gear on the crank slipped when it was overheated....the timing mark doesn't line up with anything....neither cyl TDC or BDC, or the rod journal (thats where I'd guess it should be). Any Ideas?
