Hello Gents, I recently finished rebuilding my Kohler 23hp. It idles and runs great except when you occasionally hammer on the throttle, it stutters like its getting too much fuel (flooding). The air cleaner is clean and good. Im only running the factory mechanical fuel pump mounted on the valve cover. I pulled the plugs and they are indeed wet with fuel. Ok so I found the problem, so I think! So next, I look to the manual for the fuel mixture screw, I think I found it, but when I look at the carb,,, I dont see it.
I would really hate to tear this thing all the way down again for a simple fix. My question,,, Where is the fuel mixture screw? What side of the carb is it on. What else will make it run rich on the top end when the RPM's are up (3400-4000 rpm's)? Any suggestions?
Here are pics of the carb on all four sides:
2012-06-21195547.jpg picture by fmints - Photobucket
I would really hate to tear this thing all the way down again for a simple fix. My question,,, Where is the fuel mixture screw? What side of the carb is it on. What else will make it run rich on the top end when the RPM's are up (3400-4000 rpm's)? Any suggestions?Here are pics of the carb on all four sides:
