I recently acquired a 1972 Attex Crazy Colt it had been sitting around 4 a while, I drained the gas and wired it up. A couple of days ago it would run 4 about 10 minutes get hot and shut off. Today I go to run it and it started and ran 4 about 10 seconds and died. Its almost like starting it and running it with the choke on and it floods but the choke is not on. I need some advice in what direction I should go to track down the problem.
JLO 252 Engine Problem
I took the carb off last night and when I spray carb cleaner in the fuel inlet it sprays right back out. I removed the float and the neadle that sits under the float. I soaked it in carb cleaner last night so I'll see if that clears it. Any other ways to clear it? Am I correct assuming that it's clogged?Courage Invites Critics
