Hello,
I purchased an older argo 8x8 (early 1970's) a few months ago. When I purchased it everything ran fine. It sat around for a couple months, and now I am trying to get it running realiably. It has a kohler 399ST engine and Tillston HR carb. A couple of weeks ago I replaced the condensers and points because it was only firing on one cylinder. This fixed the problem. I now have spark in both spark plugs. Before I replaced these parts it would fire up fine, but just bog down when I would go to take off. I attributed this to only running/firing on once cylinder. I thought this would fix the problem. Now, it won't start......I am hoping this has something to do with too much fuel. Fuel sprays out of the top of the carb, and is leaking slightly around the exhaust manifold. I was playing around alot w/ the fuel adjustments on the carb when it was only running on one cylinder. Looking online I found that a good starting point for the tilly carbs is one turn out on the idle and main screws and then go from there. Does that sound right? I am hoping that the starting doesn't have to do with the timing or the point gap. I set the points 0.016" however found this difficult to do, so they could be slightly off. I scribed a line in the stator plate when replacing the condensers so the timing can only be off slightly. Would a few millimeters be off enough for the engine not to start? Could someone also point me to a place to find a tool to test the timing?
I am a new argo owner, not too mechanically inclined, but willing to learn. I have enjoyed working on this maching so far, and just want to get it running good for hunting season, just around the corner. I have found a great deal of advice from this site already and looking for someone who can shed some light on my problem.
Thanks
Thanks
