need 12v fuel pump info for gas mudd-ox 40HP Kohler
  • need 12v fuel pump info for gas mudd-ox 40HP Kohler
    Does anyone know the specs for the facet brand electric fuel pump that is used on the 40 hp Kohler in the Mudd-ox. I need to order one (or the equivalent) Thanks a bunch in advance.
    Last edited by Mike; 08-24-2012, 10:32 PM. Reason: moved thread from Mudd-Ox forum to engine forum
    According to the Kohler accessory manual for your model here: Kohler Engines: Buy KOHLER Genuine Parts (found on this page: Kohler Engines: CH1000: Command PRO: Product Detail: Engines) the fuel pump kit for the Kohler Command Pro 40HP is model number 25 559 01-S. Using that number you can go here: SmokStak - View Single Post - Air cooled engine fuel pressure? and see that the Facet model number is #40177 and it is 0.5 to 2psi also backed up here: Please Help with 40 HP Kohler while mentioning that it is 7GPH flow.
    Here's one online: https://www.pegasusautoracing.com/pr...asp?RecID=7535 I'm sure there are more but Napa sells Facet pumps and can probably order one for you locally and save you the shipping. You could also contact your local small engine shop.
    Edit: I should note that I have no first hand knowledge regarding the fuel pump. This was found very quickly by me in Google so please don't take my word for it and verify the numbers / specifications yourself before you order.
      Any sand rail Dune buggy shop can get them for you as they are used for Volkswagon engines but use with a fuel pressure regulator they would have these also. You can find them on ebay in the vw parts section.
        appreciate the info guys
