Hello i am installing a 15 hp honda clone [all power] to replace a tired tecumseh and i hooked up a mikuni fuel pump to the engine by installing a pulse line in the upper part of engine base to work the pump.It seems to work delivering fuel from the tank under the seat but i think there is too much pressure for the carb float to shut off as the fuel seems to leak a small bit at the carb,wondering if i should add a return linr to the tank.Wondering if anyone ever tried this before, the tecumseh was a16 hp so i was thinking that the 15 would be alright.Also have the exhaust to reconnect and slight modification to the engine hood.Would appreciate some comments on the engine swap and any advice would be appreciated.Thank you fellow forum members.
