Hey im looking at a used set how much meat do they come with new height of lugs ect. And when are they useless and worn out any one have info or pics thanks
Argo plastic tracks
there should be no lug height (all the ones i have ever seen are flat). Check on the inside of the track (where the tire would ride) they start to wear in there. It gets thin, and will eventualy start to rub holes in the tires. Good luckAlaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
the older style had the waffle pattern on the outer face and that had a depth but I'm not sure of the depth. the newer style supertrack that i have and others have mentioned there really isn't a cleat. the cleat is flush with the face of the track and pronounced by the lack of plastic around the cleat, if that makes any sense and helps to explain some of this. i think 1/2" is probably the depth of these patterns on the older waffle style. I have seen only one set of the old style and it maybe had a 1/4" left. hope that helps some.
