Argo Tires - Tubes?
  • Argo Tires - Tubes?
    I am looking at buying an older argo magnum. My question is that 4 of the tires leak and can't be fixed. Can I put tubes in these tires instead of having to purchase 8 new tires since argo doesn't make the 20" size anymore? Any information will help. Thanks.
    If you will use the search function on the site you will find a lot of information on this topic. Here is one thread to get you started: http://www.6x6world.com/forums/tire-...bes-tires.html
    Basically, you won't want to run tubes.
      You can always put up to a 22" tire on the Magnum.I have used the 21" AT 101 from Tires Unlimited,last one I ordered was around 69.00 a tire.
        Thanks for the info guys. I'll look into new tires.
          You also dont have to buy all 8 at one time,you could buy 4 - 21" or 22" tires and keep the inflation on the lower side and the 20's on the higher side.As long as the circumference is close it will be ok till you can buy the rest.
            What do you mean they can't be fixed? I have seen some pretty torn up tires repaired well enough to hold air and function well enough for slow speed off road use. Patches are HUGE!!!
