I know there have been a number of discussions on Tracks, but has this thought come up yet?
One of the biggest problems I have with Tracks is Keeping them on the damn tires. Now, it's easier to keep the tracks on 2 tires than it is 4 tires. So, in theory, it should be easier for me to keep my tracks on if I track the front 2 tires together and the back 2 tires together. But my understanding, (From reading some other posts), is that tracking up this way can contribute to INCREASED Chain Windeup issues...... Tire pressures and circumferance is even more important.
So, If I was to track up this way, but run a Track Tuner on the 2nd and 4th axle, would I get enough grip between my tires and the tracks to keep from spinning out inside the tracks?
I know I don't have any problems spinning inside the tracks if I run one track around all tires and have Tuners on the 2nd and 3rd axles.
Would this not eliminate ALL chain windeup issues?
One concern is that there is very little of anything for the tires to get a bite on inside Supertracks. Another is that there is not enough room between the tires to run a set of Adairs in this configuration........... Unless I were to put maybe a set of 20" Tires on the machine, and then Adair Tracks (This would be easy to do with a set of "Plate Linked" Adair Tracks............. I knew I should have bought a set of those to try
Any Thoughts Y'all
I will probably try it anyway, just to see what happens
)Any Thoughts Y'all
