The adair track kit for the max2 comes with offset aluminum rims. I have had problems with aluminum rims on trucks with them not wanting to hold air. Anyone have any thoughts on this?
aluminum rims
Originally posted by tattooman View PostThe adair track kit for the max2 comes with offset aluminum rims. I have had problems with aluminum rims on trucks with them not wanting to hold air. Anyone have any thoughts on this?
Keith.
Keith.sigpic
There are a number of types of bead sealers out there. I've had great luck with Tire Slime. Almost half my tires would be low if left for a few days before putting the slime in the tires, now they all hold very well. I'm even getting lazy now and not bothering to check my tires before I ride.
Your leaking truck rims were probably a cast aluminum which are more prone to leaking due to casting defects. My sisters oldsmobile had leaking rims. The ones you would get for an AATV would be formed or stamped and not prone to this problem.Last edited by MAX IV Mark; 12-11-2012, 12:12 AM.-----\
OOO-(
Never argue with an idiot, they will drag you down to their level, then beat you to death with stupidity!
I've got a set of Douglas aluminum wheels for one of my machines. The wheels were stamped and then TIG welded into final shape. They hold air and haven't leaked any air in the 3 weeks or so that I've had them. The light weight of the wheels makes a surprising gain in performance of the machine as well. The thing with aluminum is there are several grades, I selected a 6061 (aircraft) grade and .190 thickness from Douglas which was their toughest wheel since I operate machines in difficult terrain and a wheel failure would present difficult recovery to say the least. So far the wheels are holding up great.Last edited by Noel Woods; 12-11-2012, 11:43 AM.
I ran my Super Swamp Fox in Branson Missouri after a 12" or so snow several years back. The terrain was very hilly with the snow, some snow was powder like, other areas the snow was wet. The Adair tracks pulled through every obstacle without any difficulty. Prior to that I had Vampire ASX tires on the same machine. The Vampires are great tires, but there would be no way they would have pulled up those steep snow covered slopes. Adair makes a more specialized track package now for those who live in areas of the country that get the deep ice and snow combination (with cleats).
FYI: I bought my aluminum wheels from Rocky Mountain ATV. They were reasonably priced and included free and quick shipping.
Originally posted by Noel Woods View PostI've got a set of Douglas aluminum wheels for one of my machines. The wheels were stamped and then TIG welded into final shape. They hold air and haven't leaked any air in the 3 weeks or so that I've had them. The light weight of the wheels makes a surprising gain in performance of the machine as well. The thing with aluminum is there are several grades, I selected a 6061 (aircraft) grade and .190 thickness from Douglas which was their toughest wheel since I operate machines in difficult terrain and a wheel failure would present difficult recovery to say the least. So far the wheels are holding up great.
Yes, I'd be interested to know too. I know you can get Douglas aluminum wheels in 12"x12" with a 6/6 offset and 5 by 4.5" bolt pattern.......this is a common setup for the garden tractor pulling guys that run 26x12x12's."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Originally posted by tattooman View PostAs I said in my original post, the kit comes with the rims so I can not pick my grade of aluminum. I think that because these rims are made for the watch and from a dealer with a great Rep. I think they should work just fine.
Just thought you might find some of the details interesting...
Tim :-)
That's some cool information, Tim. You should also get some standard 4/4 offset 8x8 and 5/5 offset 9x10 rims in a 5x4.5" bolt pattern......they'd sell like hotcakes!"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
