Supertrack with ice cleats
  • Supertrack with ice cleats
    I just wondering if it's ok tu buy used tracks and what I need to check. They seems pretty beat up...But I suppose they always do!!
    ha! and what would be the value of tracks like these?
    Thanks!
    Click here to see my hunting video:
    https://www.youtube.com/user/vortexw...?feature=guide
    What the size of this track ? and important to check the hinche back-lash
    Excuse mi english
    Patenteux from Québec
      Those don't actually look too bad
      Check the tabs on the segmets, where the pins run through. Check to see that the Pin Tabs are not cracking/breaking off, check the pin holes and the outer part of the tabs for wear. The pins wear the tabs from the inside out, and the ground wears the tabs from the outside to the inside.
      Check the ends of the tire guides for sharp edges. As the track twists in uneven terrain, the tire guides get forced intot he tire sidewalls and rims. The rims can dig into the guides, leaving sharp edges that will cut into the tire sidewalls.
      Those pins are going to be a Bear to remove, when it comes to that time.
        Thanks a lot...I will try to see thoses next week...
