One of the issues with this type of track is that they can be a little slippery on glare ice,which lead me to a little experiment,using sheet metal screws to stud the outside 1/3 of the track. I just used what I had laying around,but would have prefered to use a larger screw.However, the smaller screws actually worked better than I had thought.I used three screws per groser,and also added a few to the sides also.
The studs (screws) took all the slip out of the tracks,and I was able to make sharp turns,and stop/ start without slideing.As a matter of fact,the studs cut into the ice so well that they outpreformed the rubber tracks with ice cleats on hard ice.(temp. below 15 degrees.)studded track.jpg
On soft ice,(above 32 degrees) they preformed about the same.
