Reform / Reshape Tub
  • Reform / Reshape Tub
    I just bought a set of 26x12x12 Vampire tires for my Max VI and they are rubbing the tub. How should I go about reshaping the tub to accommodate the larger tires???
    There are several ways to do it. If you will search the site you will find a few threads on it. Here is a photo of how I did mine. I did this on both my Max II and Max IV. On the Max IV, I nailed several more pieces of wood together to form a wider template:
    Another way, if you have a roll cage, is to hang your Max from the roll cage so that the body sag is eliminated.
      Mike what size tires were those on your max 2, were they 9 inch rims?
        Mike put 25" tires on it. http://www.6x6world.com/forums/max-a...es-max-ii.html
        You also need to be careful to select tires that are under 25" as MaxII's have an axle to axle spacing of exactly 25"......True 25" tires will rub each other.
        Here is another you might find interesting http://www.6x6world.com/forums/tire-...html#post95939
