Can someone shed some light on the way the chevrons should be facing. My argo has them pointing forward so that the point of the "V" touches ground first. All the tractors that I've ever seen, including mine have it the other way around. My first inclination was that mine are backwards.
Tire direction?
Originally posted by quiethorse View PostCan someone shed some light on the way the chevrons should be facing. My argo has them pointing forward so that the point of the "V" touches ground first. All the tractors that I've ever seen, including mine have it the other way around. My first inclination was that mine are backwards.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
V'S FACING bACKWARD
Originally posted by rdr View Postif your v are running like a reg tractors forward they will not swim .you have to have them riunning backwards for them to swim. e bringing the water from the outside of the tire to the center of the tire . a pic would be worth a 1 k words .
I was thinking that most Argos sit nose low in the water with the very front wheels almost completely submerged limiting their propulsion. I'm guessing if you ran the front tires in the traction position it shouldn't slow the water speed that much but would increase the traction exiting the water or mud hole.
Mike"Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
Here is an even bigger Looser!
This guy needs a life. He's ugly and walks funny too!Last edited by fulleraviation; 03-28-2008, 07:39 AM.2007 Max IV Hot Rodded Vanguard 18HP?
Hi-Speed Clutch, Vampire ASX, 35MPH
for traction in mud and easier self cleaning of same, point down looking from the front, for swimming and super loose material, opposite.
That has always been my experience with heavy equipment.
If the point is "up", they will get short term very good traction, but, will load up with mud fairly fast, and, not clean so well......
IMHO.........as always, others results may vary.......
good luckHenry:
