I finally got out to play in the water!!! new tires--red spring--950 huslter. Now keep in mind I am about 220 pounds and a friend of mine in the back seat is about 240. The Rock River has flooded alot of fields here 'perfect training grounds' In mud and water 1 to 2 foot deep was not even a challenge, Big logs no problem, if the nose of the unit starts over it , we could kroll over it!! In deep water, we had problems!!! As long as i kept out of the throttle 'just a little more than idle' we did move very slow!!! If I gave it the gas the tires would litteraly pull the back end down takeing on water!!! OK don't do that. Now the scary part, in a fllooded field 1-1 1/2 foot of water, there is a very steep hill at the end,'aha a challenge!!!!' DON'T DO IT says Dany my back seet driver. From a dead stop the machine went right up the hill with no effirt, at about 10' up a small log was enough to make me panic ' fear of a role over' I pulled back into 'neutrol' and down the hill we go at rocket speed, Big spash, we're in the water again!!! To finish the story , we are both soaked , Dany walked back to the truck, pist off . I LOVE MY AATV Dany says he has to get one!!
Super Swomper Report
Hey Russh,
Thanks so much for the info.....due to this I will probably go ahead and try the TSL Vampires, I will post up a report when I get to swim it. But in reality, as long as you get a little forward motion, that will be good enough to get you out of most spots. You have me excited to try out my red clutch spring! Only downside I see on the Vamp's is perhaps a rougher ride, and they supposedly have good lateral traction, so I wonder how they skid steer??
Did the river Nazi's see you?Hammers should have warning labels.
Originally posted by Russh View PostI finally got out to play in the water!!! new tires--red spring--950 huslter. Now keep in mind I am about 220 pounds and a friend of mine in the back seat is about 240. The Rock River has flooded alot of fields here 'perfect training grounds' In mud and water 1 to 2 foot deep was not even a challenge, Big logs no problem, if the nose of the unit starts over it , we could kroll over it!! In deep water, we had problems!!! As long as i kept out of the throttle 'just a little more than idle' we did move very slow!!! If I gave it the gas the tires would litteraly pull the back end down takeing on water!!! OK don't do that. Now the scary part, in a fllooded field 1-1 1/2 foot of water, there is a very steep hill at the end,'aha a challenge!!!!' DON'T DO IT says Dany my back seet driver. From a dead stop the machine went right up the hill with no effirt, at about 10' up a small log was enough to make me panic ' fear of a role over' I pulled back into 'neutrol' and down the hill we go at rocket speed, Big spash, we're in the water again!!! To finish the story , we are both soaked , Dany walked back to the truck, pist off . I LOVE MY AATV Dany says he has to get one!!
Russh ,
I know the very first time I drove my Max IV into a pond , I was a little nervous , but that feeling soon past as I watched my Max IV swim across the pond at a impressive speed ( 5 psi in all the tires ) .At that particular time I was running the factory Good year Terra tires . These tires are the very fastest in the water and the Argo Frontier tire is a very close second . I later bought some used GBC Gator tires to install on my Max . When I got the 26 " Gator tires installed on my Max IV , it looked really impressive for an amphib . I had been told on the forum , that the Gators would ride like stones,,,so I ran them at zero air pressure , because they were 6 ply and I have bead lock rims.
Hmmm ,,I thought to myself ,this is not as bad as I thought , as I drove my Max IV down an ATV trail . I took my Max IV down some very muddy ATV trails and jeep roads , and the Gator tires performed great !
My next test for my Max was a large pond . At that particular time , I had all the Gator tires facing backwards , thinking this would give me the best water speed . Since I had lost my initial trepidation of driving into deep water with my Max IV ,,I had no fear of driving down a shallow bank into the pond . When I was about 15 feet from the bank , it was then I noticed that my Max was going side ways , instead of forward , when I gave it the gas .
I then put my Max into reverse and tried to swim back to the bank . This worked a little bit better ,,but not much . When I finally got my Max IV back on dry ground , I decided to change my Gator tires to the foward position , at 3 psi . In this tire postion ,the Gator tires would paddle " VERY" slowly if I used very little throttle in deep water .
I then tried Gators on the front and Gators in the middle of my Max IV ( facing foward ), with the Good year ,Terra tires on the rear , facing backwards . This tire combination proved to be exellent for mud , and also enabled me to make it across the pond . I later found out that this tire combination would not work if the water had a mild amount of current . I now have Gators in the front ( facing fowards , for climbing out of the water ) and the Good year , Terra tires in the middle and rear , facing backwards . This tire combo works well .
boncrshr ,
Dan and I both have changed to the red spring and we both love the low end torque it gives us for climbing hills with extra weight . The Vampires are harder to skid steer because the side lugs are not tapered like an amphib tire . They also have side lugs that give you an advantage when climbing out of rutts . The side lugs also make it harder to skid steer , but this can be over come with more throttle .The Vampires ride -->VERY good <--- at 2 psi , but Dan told me that he had to use an 1 1/8 aluminum spacer to prevent rubbing of the inner tub when I made turns . 3 psi might be a better choice if you don,t have the tire clearance .The Vampire tire will probably be your best choice in a ATV tire in that rim size .
