tracks for a swamp fox
Swamp Fox any one have an info on tracks
What exactly are you looking for Russ? Noel Woods is running Adair tracks on his Super Swamp Fox. I don't know of any one else that has even tried as of yet.
Are you looking at putting them on a "standard" Swamp Fox (that fits ~22" tires or so at the larges) or a Super Swamp Fox that'll arguably fit a 27"-labeled tire?sigpic
Yes, I have a set of Adair tracks on my Super Swamp Fox. I have a set of Goodyear Rawhide tires in 25 inch size. They fill up the wheel wells with the tracks but there is no rubbing.
I think a set of new Adair pro tracks with the 24" Argo tires would also be a great set up for a S.S. Fox.
The track length is nearly the same as that of an Argo Frontier. I believe I had to remove one grouser to shorten the length slightly to make it work.
A regular Swamp Fox, I don't know if they would work, its been many years since I've fiddled with a normal S.F. but from what I recall, the upper body does not have any where near the upper clearance of a S.S. Fox. Tracks can almost always be used but it may be necessary to drop the tire size down to a 21" or maybe even a 20".
