Hi,
I was wondering how ice build up in the guides affects track tension and chain wind-up?
Right now I run 3.75 PSI in each tire and the tires are sized correctly, largest at rear, smallest in the front. This gives me 1 1/4 track tension with the vehicle jacked up off the ground and measuring from the center tire to the track.
I was out today in deep snow for about 6hrs and near the end of the day I had ice build up between the tires and track guides. The reason you measure tire circumference and tire pressure is to set track tension, how do you account for ice build up?
Thanks.
Thanks.
