I have an older 6x6 Vanguard that has the Goodyear Runamuck tires. The 3 on the left side are badly age cracked on the sidewalls and had air leaks at the bead. My local tire shop found no leaks on the sidewalls, which was a surprise. They cleaned the rims, sealed the tires on the rims, and put Slime in them. They put 7 PSI air in each tire. I read where the maximum PSI for my tires is 5. I know that 7 PSI will make for a rough ride, but I don't want them to leak at the rim or pop off of the wheel. What do you think of having 7 PSI in these tires? I DO use plastic tracks for winter.
A second question is about Slime. I've read mixed reviews on it. The positives are obvious. That said, I've read that A) in extremely low temps it will freeze so antifreeze needs to be added to it. B) After about 2 years in the tires it will harden and need to be cleaned out and replaced with fresh and C) the turning of the tires will keep it on the tread and it will therefore not coat the sidewalls and seal any leaks there. The tire shop put Slime in the left 3 tires but the 3 on the right side have none. Is it worth it to put Slime in those 3? Thank you all for any replies.
