4x4 or 5x4.5 bolt pattern atv rims...
  • 4x4 or 5x4.5 bolt pattern atv rims...
    Hi. Are there such things as 4x4 or 5x4.5 bolt patter atv wheels?
    The Honda Rancher atv wheels sre 4x110mm. Close but no figar. Thanks.
    No 5 x 4.5" atv rims, but there are many applications for this bolt pattern. Suzukis, fords, lots to choose from. 4x4 is rare, MGs are the only thing I know of that use that pattern. 4" is 101.6mm
      4 x 100mm might be able to work. 100mm is 3.94" or 3 47/50". Probably close enough.
        Thank you. I would like to build a teardrop trailer for my Max IV to tug about occasionally and wanted to use atv tires 26" or a bit larger.
        The hubs/spindle kits I found use either 4x4 or 5x4.5 wheels.
        I have no problem using the larger trailer tires though.
        Thsnk you for responding.
          I found an altenative...
          4x4 to 4x110 adapters. Cost is about $75 each.
          Doable, but costs more than the trailer hubs.
            4X4 is a common trailer rim pattern, dont think you will fine many wider than 8"
            Acta non verba
              Measure your Max wheels and tires.
                Please tell me this is a hint. (My Max IV is in storage. No imediate access)
                I' m hoping its 5x4.5.
                  http://www.6x6world.com/forums/tire-...tml#post106003
                    Thank you.
                    After rewording my search I found another thread that had a link to a company selling steel wheels, 8x7 rims with both 4x4 and 5x4.5 bolt pattern. Price is a bit under 12 dollars.
                    The largest general use atv tire I am aware of are 22x11-8.
                    I think I will buy these wheels and go with the 22" tire size, most likely set up as duelies.
                    Thanks for the help guys.
                      A teardrop for camping? That you pull around in the bush. Living quarters for the roadless traveler that doesn't involve setup (much).
                      Now that is a build thread to watch. <hint>
                      Mention it over on expeditionportal and show them AATV camping where those megaroamer apartments dare not tread.
                        John F.... Thanks for the interest. Yes, a simple squared up 4x4x8 teardrop (might end up 5 wide though). Off-road teardtop style.
                        My brother just gave me what is supposed to be a utility trailer with a 4x4 deck, with little wheels. It it rated for 1740#.
                        He got it free. Missing the leaf spring bolts. Maybe other stuff.
                        Its buried under the snow in his yard.
                        Well, this is a start. It will need to be made longer. Duel axle mods, too. Plenty of trailers parts online.
                        Obviously a build thread won't start til summer. Fun, fun, fun.
                          Thank you.
                          What was your source? I'm looking for some 12"x8" rims with the 4.5x5 bolt pattern to fit ATV tires to the Coot.
                            If you want a 12X8 5 on 4.1/2 wheel go for a garden tractor wheel. Like wheel horse, john deer, and many others . Thy use this pattern.
                              Thanks!
