Just to let you know, last weekend I installed 2 Stryker 25x12x9 tires on our Avenger, due to excessive sidewall failure with the Goodyear. The tires while only 1/2" wider, do appear larger in circumference than the stock tire, and I doubt the track will fit over them. I did not do a circumference measurement but will this weekend. The tires performed very well on rock and in mud and offer a much more agressive sidewall for grabbing mud and side channels. The larger tires fits well under the avenger, however there is less of a gap between the next tire (hence why I plan to measure circumference). They are a much more cost effective tires (I paid $89 per tire in Canada vs about $180 for the Goodyear Rawhide III 25x11.5x9.
Carlisle Stryker Tires on Avenger
Man, what a difference in price. Is this the tire: Carlisle Tire & Wheel Company
If so then there is a (supposed) 1.2 inch difference in the advertised diameter. The 25" Goodyears show up as 24.0" diameter on Goodyears site: Goodyear ATV - All Terrain Vehicle Tires: On The Wings Of Goodyear: Find the Right Tire
The Strykers are showing 25.2". It will be interesting to see how they compare to each other in the real world when you measure them.
Couple of questions:
How do you think they will ride compared to the Goodyears?
Also, what kind of sidewall problems were you having with the Goodyears?
Hi Mike, yup that is the tire we have. Since I only have 2 out of 8 on right now, it might not be a great comparison for ride, but we did have a less jarring ride then with all goodyears on it. Our problem with the goodyears, were constant sidewall cuts, which I attribute to the Avenger fitted tire. We previously ran a bigfoot with the 12" wide rawhides, on all the same trails, and rarely came out with a flat. With the 11.5" tire, we always came out with a minimum of 1 tire cut through in the side wall. On one ride, we came out after 4 hours on 2 tires with air, the rest flat. Plus we also noted that the sidewall would puff out after a hard ride, as if they were weaker than the 12" tire. If you can visualize the tire starting from the rim, the first inch looking normal on the rim, and then it would puff out about 2" further than the rim, and then slope back as you got to the top, so that the top of tire was narrower than the middle. Probably hard to visualize with my description, but a tire should expand at the outer edges first but these were not. We thought perhaps we have a bad batch, we took pictures, and got the dealer involved with ODG, but there was no 'fault' found in the tires. That's the way they are and it must be the type of trails we were running. I would buy that if this was out first Argo, but it's out 3rd and on the exact same trails around our cottage.
RS Bolduc told me the tolerance on outside diameter for the rubber track to still fit and I am going to try and track that down.
You will notice the Stryker has some pretty solid lugs along the top sidewall for grabbing on the inside of ruts etc, and physicall look thicker in the sidewall than the GY.
Hope that helps.
That's very strange on those Goodyears. It's a shame that they wouldn't help you out since it was obviously a bad batch. Plus you are a good customer
I think I may have seen someone running those Carlisle tires on another Argo in one of John Schwab's videos. I will have to go back and see. Anyway, thanks for the info and let us know what you find on the tracks and if you go with all 8 tires report back with some comparisons.
Sure thing. I only have a couple of pictures where you can see them. I still only have the 2.
MobileMe Gallery
p.s. I am not in any of these photos. Tires are on the Avenger.
I have also lost several tiers on my 05 Avenager. In every case the side wall gets pinched against the rim and slices the tire, from large rocks, banks, ect. It seems to hapen more when under a load, like on a hunting trip. With more air presure in the tire it helps but the ride is rougher. I want to find a replacement tire and swap them all out. the few rawhides that are not tore up i can use on a trailer.
i have these duro on my attex bruiser i beat the crap out of them and the nipples are still on them same as the stryker alot cheaper. i ride on very rocky and rooty area and alot of hill climbing and MUD MUD AND MORE MUD.
Duro Front or Rear HF-243 22x11-8 Tire - DennisKirk.com
duro 25"
Duro Mud and Sand ATV Tire | Rocky Mountain ATV/MC also found on my search that walmart carries the stryker tires i will check next time i am there
