Well I ll try and keep this short, while changing the axles on my conquest when I was done and in the air I ran it and noticed that the chains on left rear and left 2 nd from rear are loose on top onoy fiddle string tight on the bottom. I ran it in reverse and it straighten right out perfect tension top and bottom of chains. Took of jack stands and test ran approx 1 mile and loaded right back up left rear chain tight on bottom loose on top that its dragging on the frame . HELP. I have a set of the Adair 18 inch tracks on it and all the chains are tsubaki approx 20 hours on every link in the tub. Is there anything I'm missing??? Almost seems like it s loaded up like no slippage between tire and track on the left side. Is this possible?????
help chain loose with tracks on
You need to properly index your tires to prevent chain windup. Argo recomends a differnt tire pressure for each position, someone will post it I'm sure. IMHO, the only way to do this properly is to measure the circumference of each tire at a set PSI (start at 5 psi) with a tape, then adjust your air pressures to equalize the circumference of all tires. I do this by letting some air out of the larger tires until they all measure the exact same circumference. I used to write down whatever PSI each tire required with a paint pen right on their respective rims. Another option to eliminate chain windup is track tuners, they are esentially free wheeling hubs you install on your center axles to turn them into idlers.
Yes as said above but I think that almost everybody recommends track tuners on the center axles of 8 wheelers with Adair tracks. I hope someone corrects me if i am wrong.Originally posted by Canadian_Zuk View PostYou need to properly index your tires to prevent chain windup. Argo recomends a differnt tire pressure for each position, someone will post it I'm sure. IMHO, the only way to do this properly is to measure the circumference of each tire at a set PSI (start at 5 psi) with a tape, then adjust your air pressures to equalize the circumference of all tires. I do this by letting some air out of the larger tires until they all measure the exact same circumference. I used to write down whatever PSI each tire required with a paint pen right on their respective rims. Another option to eliminate chain windup is track tuners, they are esentially free wheeling hubs you install on your center axles to turn them into idlers.
