Pulled my Hytrotrax out to get ready for duck season and noticed I have a flat tire. Hoping some green slime will stop the slow leak, but if I have to replace the tire I am dreading pulling the track pin to pull the tire...getting it on was a pain. Anyone ever pull all three tires and the track together...repair or replace the tire...put full assembly back on?
Flat Tire with Tracks
My experience was the same. Shop vac is the way to go. Pull the valve cores, vac the tires down onto the rims and stick the valve cap back on to keep your vacuum. Install your tracks and inflate the tires. I start with just the front and rear tires on, fight the tracks on, then I install my middle tire. My tracks are a continuous loop though, I wish I had a fancy hinge pin.Originally posted by SlimChance View PostI tried that ONCE, didn't work for me. I ended up sucking all the air out of the tires with a shop vac to re-install them with the tracks.
flat tire with tracks
I just held the hose end over the valve stem as tightly as I could and the shop vac sucked it flat.Originally posted by Bscout View PostThis is a great idea...it is only a matter of time before I have to pull a wheel. I have an old shop vac, but no attachments that would fit in the valve stem...did you jury rig something or is there a part I can purchase?
I tapped a piece of 3/8 fuel hose into a small attachement ant it sticks over the stem without holding it. In the field I wrap rope or strap arround the tire and twist it up to crush it. Install the cap until track is back on, then install center tire and inflate.
I've got this attachment for my shop vac that works great on the valve stem. Not sure where to get it though. The guy I got the machine from gave it to me.Attached FilesWhat it lacks in ground clearance it makes up for with traction.
