I seen some pics the other day of a Outfitter with a set of split tracks on it(4 tracks as opposed to two)and was wondering how well they worked,the fact that they are strung around just two tires rather than all four does it help/hurt chain windup is it less capable in mud/snow I have zero experience with this type of set up and puzzled as to why and what advantage this would have.NCT
Split Tracks
I believe you eliminate most of the chain windup issues but lose surface area of track on the ground compared to one track per side. Also can run into clearance issues between the two middle tires. Search Half tracks I believe there is a few reviews kicking around.
Originally posted by SHOTGUN View PostI believe you eliminate most of the chain windup issues but lose surface area of track on the ground compared to one track per side. Also can run into clearance issues between the two middle tires. Search Half tracks I believe there is a few reviews kicking around.
I also believe it does just this, you will need 24 inch tires for clearance and they run turfs. I'd email Tim or Fritz about flotation. Naturally you currently do not have enough track to do it with what you have.
The Argo version is spendy.sigpic
Yea understood ArgoJim I do use the frontier tires on my Avenger with tracks on i like more clearance to the body for the tracks as well as a lower overall ratio,i have found another used set that were torn up but enough left with mine to do a 4 track system the thing that is more spendy then I thought is the hinge kits Geez they want enough for those pieces of tin,but yes more research is necessary before I commit.NCTOriginally posted by ARGOJIM View PostI also believe it does just this, you will need 24 inch tires for clearance and they run turfs. I'd email Tim or Fritz about flotation. Naturally you currently do not have enough track to do it with what you have.
The hinge kits do demand a premium, if you get your questions answered sounds like that may be your only expense. Maybe the resident track guy knows some answers as to the split track, I think he even had a thread about some.sigpic
a dual half-track system does give you some extra redundancy in the event you have an issue with a corner axle, bearing, or tire/wheel. Having 1 remaining half-tracks on each side means you're still very very capable in comparison to having only tires. Having 2 half-tracks on each side of an 8-wheel machine gives you the same footprint on the ground as single 6-wheel track (installed over 3 tires on an 8-wheel machine) would. So if you want equivalent psi reduction to an 8-wheel track, you just need to make each half-track wider. Because each half-track is on each corner, it does balance the footprint of the machine nicely though. A half track is more difficult to drive out of, just like a 6-wheel track is more difficult to drive out of than an 8-wheel track. Aside from that, the particular track-style used to make each half-track would further affect certain traits of the track, some of which are very significant.
In regards to chain windup (resistance the tires are forced to work against or forced premature rotation of certain tires by the track itself), it doesn't go away simply by using (4) half-tracks instead of (2) full tracks. The difference in circumfrence between tires must still be scrubbed-out while inside the tracks. This is mostly a factor of how easily the tire treads can do this against certain track surfaces or track grouser types. Having a loose track can help, but this can also cause track-driving problems for certain track styles.
I believe argo uses dual half-track systems on their larger/heavier machines because the track stays on better and the shorter track can be driven a little more effectively when the tires might otherwise slip inside the track more often. Because of the factory track is a flat track with moveable guides, some added resistance to falling off is desirable. Their higher load rated turf-style tires on 12-inch rims are probably more consistent in circumference too and also have a very smooth tread design that can slip in the track a bit easier, even if the track has a bit more track tension (which will also help it stay on better).
Not a perfect scenario or my favorite track style, but I think the dual half-track set-up helps the reliability of the rubber track, especially on heavier machines.
It does come down to clearance between axles, and tire size + track height come into play. With an avenger/frontier 8x8, you're looking at a true 24" tire + a track height of 1" (maybe 1 1/8" max) to allow clearance between axle #2 and #3.
Depending on your particular set of 24x10x8 tires, the factory rubber track may or may not work in this scenario. It may be necessary to use smaller tires or a lower-profile track
If you were to make rubber tracks to fit over (2) tires instead of (4) on your machine, take the distance between axles (26.33") x 4 =105.32" and subtract this from your full-length track that you currently have. That will tell you how long each half-track needs to be in inches. As stated before, you'll need to obtain some more belting to make it work.
I have tested many half-track set ups using elevated-belt tracks and different grouser types. That of course is a different discussion altogether.
Thanks Buzz,I did was uncertain of the clearance and have since got a chunk of a tore up one here and when I dig the tracks out in the next week before the hunt I will wrap the centers just to get a idea,I totally understand and agree on the windup issue it was not my primary goal that was redundancy my hope was that only having to keep two tires as close to the same diameter rather than four that said i have went by Argo,s recommended install technique and have not broken any parts since the axle upgrade,with this read perhaps I would be poking the sleeping dog with a stick and should rethink this and the point about turf tires I had not considered,give a guy more to think about before leaping in.NCT
I have a 88 argo 8 wheeler with the Kohler 17hp. The full set of tracks was way to much drag on the engine, just not enough jam.
I spilt the tracks (plastic) and half tracked it. Put them on the front with grippy tires on the rear axle.
Very happy with the results. We have been dealing with deep slushy snow. It can still get stuck, but so far has been the best performance we have seen from this machine.
It will also cross, incredibly this ice as well. We played around on it long enough to eventually break through, but suprised me how little ice it would cross. Loaded with two adults and a few hundred pounds of trapping gear.
I wish I had the power to run two half sets
not enough power and hard turning are some of the most common complaints with tracks. One of my favorite set ups is quad-track channel track set up. Because of the low-profile grouser, many machines already have the clearance to do it without needing different tires, and you get the benefit of a slower driven track belting and gear reduction. No track tuners needed. Half tracks have really impressed me. I used to be skeptical, but no more
quad tracks on conquest with 22x10-8 runamucks
did this a few years back with the mudd-ox. Had an old demo channel track so decided to do the same. No prob on clearance. Doesn't require track tuners.Attached Files
Thats the setup i want to try the last statement is great no tuners Buzz you the track man.Cheers NCTOriginally posted by Buzz View Postdid this a few years back with the mudd-ox. Had an old demo channel track so decided to do the same. No prob on clearance. Doesn't require track tuners.
There's a few machines up here doing it now, I'll keep you guys posted. It seems to further improve upon the track style, especially for older lower hp machines, or heavily loaded machines that want increased reliability and a redundant set up.
