I have a Vanguard with 22x10x8 runamucks and Argo super tracks. Will the Carlisle 101's in size 21x11x8 tires fit with the tracks?
Thank you
Its not a perfect match but will work have you a early build of Super or the later build there was a difference the early build will scrub the sidewalls a bit more with the Carlisle but nothing drastic if winter use only had to up fit to the newer tires on my last Conquest on the supers it worked fine.NCT
Not sure if I have the older or newer super tracks. I read where some people bolt chain across the tracks and there are ( I believe) 3/8 holes on each end of each track segment. There are no holes on my tracks. I'm thinking,maybe older tracks? I am only going to use the machine in the snow.
Sounds as if you have the 13" wide tracks, the older style are a straight across full face track, the newer style has an indented lengthwise cleat built into it.
