I plan on using my tracks all year round. If I install ice cleats on them, how will that affect dry weather use? Thanks.
Track Ice Cleats
I've been thinking about that idea. I bought the Argo cleats that are attached by separate bolts for each cleat. If the bolt isn't damaged I think a couple hours of work in the spring would take the cleat off and then repeat the process in the winter.Originally posted by john swenson View Postcrossbow, maybe your best bet would be come up with a fairly easy way to install and remove the cleats. depending on what style the tracks are there may be some folks on the site with some good ideas how to do that. what kind are they ? johnboy
the most reliable type of traction is one that bites forward/backward, but does not bite or prevent the machine from skid-turning. You have to skid turn to navigate no matter what, and I've learned to avoid traction enhancers that provide resistance to the track sliding laterally. They go in a straight line very well, but there are a lot of other conditions you will be running in.
I just finished putting the argo cleats on my rubber track.did not use the crappy allen head bolts that argo supplies but went to the hardware supply and bought 50 hex head bolts.will make removal real easy.
Originally posted by crossbowme View PostI've been thinking about that idea. I bought the Argo cleats that are attached by separate bolts for each cleat. If the bolt isn't damaged I think a couple hours of work in the spring would take the cleat off and then repeat the process in the winter.
I actually did just put them on when I posted,i **** you not.lol the main reason I bought them was to stop spinning out on 2 steep hills I have to climb to get out ice fishing.today while plowing snow again,i did notice that I was not spinning on the glare ice under the snow.the cleats seem to hook up real good.just have to take it easy so I don't twist an axle off.
Originally posted by crossbowme View PostHave you noticed any real difference on the trail yet?
Did you use any loctite? I'm about to install and was worried that with vibrations I might lose a cleat. I was also thinking of getting my own bolts and use locking washer rather than loctite.Originally posted by plott hound View PostI just finished putting the argo cleats on my rubber track.did not use the crappy allen head bolts that argo supplies but went to the hardware supply and bought 50 hex head bolts.will make removal real easy.Last edited by puzle; 02-16-2017, 09:08 AM.
