Wheel bearing extension cages.....Max4
  • Wheel bearing extension cages.....Max4
    Where can they be found
    #40130 on max6x6 if you have 72mm bearings. Will have to find used I believe if you have 62 mm bearings.
      couldn't you use them even with the 72mm bearings if the ID for the axle was the same? I guess the bearing cages might have a different bolt pattern for the bearing flanges 72 verses 62 so bolting up to the outside would not work. just a thought.
