some of my rims are leaking around the tire and rim area. due to dirt and some bends in the rim. i want to buy new ones but first is there any way i can reuse them if i take the tire off and bend them back strait and clean up the beads? how hard is it to do yourself?tips?
rims
If the rim isn't bent badly, it may just be the tire that is the issue or, if you've reseated the bead in the field, it could be a dirty bead. You can break the tire off the bead, leaving it on the wheel, and clean everything really well. If it's rusty, wire brush the wheel and repaint. Then reseat the tire's bead on the wheel.
You could always put tubes in them. They are inexpensive when it comes to rim and tire replacement.Originally posted by curtisbyrne View Postits mostly because my rims leak and they get flat and when turning all the dirt and sand gets around the bead and frigs up the seal. there are some small rocks in my tires as well... you can hear it rolling around in there."Racing is life. Anything that happens before or after is just waiting."
After cleaning the rim up, you can put a thin bead of Permatex on the rim and/or tire and reseat it. We've had a lot of good luck stretching the lifespan of old rims and tires by gluing the living h*ll out of big and small tires. The silver bell trailer wheels are wicked cheap if you want to upgrade. These have a really decent bead on the rim and are well worth $12/each.
8X7 5-Lug on 4.5" Silver Bell Trailer Wheelsigpic
I have those wheels on all of my machines and I like them a lot.Originally posted by hydromike View PostAfter cleaning the rim up, you can put a thin bead of Permatex on the rim and/or tire and reseat it. We've had a lot of good luck stretching the lifespan of old rims and tires by gluing the living h*ll out of big and small tires. The silver bell trailer wheels are wicked cheap if you want to upgrade. These have a really decent bead on the rim and are well worth $12/each.
8X7 5-Lug on 4.5" Silver Bell Trailer Wheel"Racing is life. Anything that happens before or after is just waiting."
They hold the bead fine. I think Egoperf measured the bead on the silver bells and compared it to the K-lock bead and it wasn't much of a difference at all. They hold quite well as-is. With that said, I'm running them naked and with a couple sets of Smud-Locks on the racers and am happy with the few laps they've made so far.sigpic
I tried all last winter to get my old original 22" runamuks to hold air. I thought I had it beat after I wire wheeled the beads all down and sealed the beads with automotive bead sealer. But as soon as I took it out they started leaking again and I said screw it and bought 8 new wheels and tires. I believe the tires themselves were so gouged up on the beads that they wouldn't have seated on new rims either. Something to check on before you go buying new wheels.
