Looking to put tracks (channel?) on my 6x6 Frontier. What are the pros and cons of using spacers vs a rim with a 2" offset? I won't be swimming. What tires would you recommend for the tracks?
Spacers vs offset rims for tracks
The stock Argo spacer on their 18 inch tracks is 2-1/2, check with Channel on recommended spacer width and tire sizes for you particular machine. The manufacturer should have an ideal fitment for each machine the track is installed on.sigpic
It makes no difference on these vehicles whether you use a spacer or an offset Rim. The end result is the same amount of Leverage exerted on the axle. Using a spacer makes it easier to go back to a narrow width with Tires Only. The advantages of an offset Rim are fewer mechanical fasteners and in theory it should run truer
Agreed, my comments were as to the 1/2" difference which could result in much unwanted tub destruction. Even with the 2-1/2" spacers tub contact is possible with the 18 inch track if a tire psi becomes low or tracks are loose, the lower belting of the channel track may be less likely however I have no experience with that so my opinion is moot.Originally posted by Canadian_Zuk View PostIt makes no difference on these vehicles whether you use a spacer or an offset Rim. The end result is the same amount of Leverage exerted on the axle. Using a spacer makes it easier to go back to a narrow width with Tires Only. The advantages of an offset Rim are fewer mechanical fasteners and in theory it should run truersigpic
Yup, as Can. Zuk and Argo Jim have said , where you get the extra 2 1/2 inches from makes no difference. Spacers or extra wheel offset is all the same. as a point of interest I have been using 20 inch wide rubber tracks from R.S. Bolduc for a few years now on two different Avengers without any problems just 2 1/2 inch steel spacers.
