I will eventually, have a set of these tracks, funds pending, but I was wondering if anyone that owns these has ever considered cutting an inch or two off them to have a slightly narrower footprint? From the looks, there is ample extra rubber outside the guides to do this...just wondering if it has been done.
18” Argo rubber tracks
i suggested this to someone else recently whose tracks were to close to the tub. i don't know why it would not be feasable to trim some off unless it would compromise the strength or something. i would use a jig or reciprocating saw with a fine tooth blade. maybe clamp a guide to the track to get a straight cut. i've cut plenty of wide belting that way and it worked fine. johnboy va.
Originally posted by john swenson View Posti suggested this to someone else recently whose tracks were to close to the tub. i don't know why it would not be feasable to trim some off unless it would compromise the strength or something. i would use a jig or reciprocating saw with a fine tooth blade. maybe clamp a guide to the track to get a straight cut. i've cut plenty of wide belting that way and it worked fine. johnboy va.
Why would you want to take away from your flotation by trimming the inside. There's ample room and if it does scrub it's not much an issue as it tends to scuff the skidplate if anything... I can understand the overall width being an issue, I get it, but I wouldn't compromise performance trimming the inside. If anything it may allow more room for logs and branches to get caught between the track and the tub which was a pain in the butt for me when I had them. They would pull over and jam between the middle tires and cause sidewall flats for me, normally pinhole leaks. I eventually tubed all 4 inner tires with the rubber tracks because of this issue and my tracks were full width not trimmed.
Originally posted by Sparx View PostWhy would you want to take away from your flotation by trimming the inside. There's ample room and if it does scrub it's not much an issue as it tends to scuff the skidplate if anything... I can understand the overall width being an issue, I get it, but I wouldn't compromise performance trimming the inside. If anything it may allow more room for logs and branches to get caught between the track and the tub which was a pain in the butt for me when I had them. They would pull over and jam between the middle tires and cause sidewall flats for me, normally pinhole leaks. I eventually tubed all 4 inner tires with the rubber tracks because of this issue and my tracks were full width not trimmed.
Yes it’s the overall width that would be my issue. No other reason.
Originally posted by john swenson View Posti sure would not think that a trim of 1/2'' to 1'' would loose you that much noticeable flotation ? better than rubbing a hole in the tub it seems to me. j.b.
