What do you think about tracks for mud and snow for my 2018 argo outfitter. Anybody have any experience with beaverdam tracks. Please leave feed back
Adair tracks or beaverdam argo tracks
You will have to check with Adair on Outfitter availability, a few years back I had asked about the Centaur equipped with Adairs and there was a possible weight concern.
I'm sure development may have progressed.sigpic
I am resurrecting this dead thread as opposed to starting a new one. I am curious about both these track systems and would love to hear additional feedback if anyone out there has any experience with either of the two...
Specifically, how have either of them held up? Performance on the water?
I'd be putting them on an old '95 Response 8X8.
I do not think the Beaver Dam tracks would fit on a Response without going to a smaller tire. Most people are happy with the Adairs.Originally posted by Redhorse View PostI am resurrecting this dead thread as opposed to starting a new one. I am curious about both these track systems and would love to hear additional feedback if anyone out there has any experience with either of the two...
I'd be putting them on an old '95 Response 8X8.sigpic
not sure how much under-tire thickness Beaverdam grousers have, but they’re probably similar. As long as you have 22” tires, you’d be okay. Wheel spacer-wise, it depends on how high their belt height is in comparison to rear bearing extensions (if your machine has them). More than likely, you’ll need a larger-than-factory spacer because the beaverdam grouser is very square (or it always used to be) and has a wider contact patch. So unless the guides (and belt) are very low, then they’ll probably require oversized spacers. 10” wide tires vs 12” do offer additional clearance all things being equal, but grouser width on the inside and belt height will determine. ….unless they’ve tweaked it to be like other builders
Tracks are always going to be superior to just tires. It took me many years to accept the concept. I have Adair tracks and am happy with them. I've seen another Argo HDI with Beaver Dam tracks and it performed well too. I think that the selection is a customer preference situation like Ford vs. Chevy. In a pinch I would take either.
have you bent and/or broken any of your grousers? Also, what width wheel spacers are you using with your tracks and 25x12? tires?Originally posted by scimanstev View PostI am running all steel Beaver Dam tracks with 25" tires. I have plenty of extra cleats, so if one breaks because I definitely climb over many loose rocks, then I just swap it out and keep going. I love the Beaver Dam tracks, but certainly both Beaver and Adair are very good tracks.
The original poster may have purchased new tracks by now?
Yes, bending isn't the problem. The trails I have access to have loose rocks. Some of them are about 100 pounds. The welds on the grousers can break, which can lead to bending. It's the oldest ones that break. It's not hard at all to swap one out. The tracks themselves can't come off unless an entire wheel comes off, which has definitely not happened, or the two 6 inch bolts holding the Kevlar together breaks, which has also never happened. The traction of these tracks is incredible. I have gone up a 60 degree heavily mudded incline with ease.
The spacers I use are from Adair. I use their track tuners. I just read all the information from this website, and bought from wherever a product came from. My entire machine is made of the best parts I could find. Warn fog lights, gas tank plumbed directly to the outboard motor, as well as electrical, air brushed pictures of Juggernaut on the hood, and I rewired most everything.
