I have an Argo 6x6 with Goodyear rawhide tires , whats the best way to keep air in these things , seems like I spend most of my time filling them up . Does anybody use tire slime , or tubes ? , what works best ?
What's the best way to make these tires hold air
I used Slime in my Argo. I love it. I had leaks around the rim. I went from filling up my tires ones a week to filling them up once every 4 months. It also helped with breaking the beads while riding. I guess if you break a bead it will seal it back up fast.
you might consider getting some bead lock rims from Matt O on this forum as you can run as low as 1 psi with his rims and not break the bead in fact he says you can remove the valve stem and not lose the bead. I had the same problem with my Bigfoot argo breaking the bead.
Ditto on the slime! I did break a bead one time with my Vampires/MattO rims
Not knocking them though...I only run 1-2psi. Mudbug broke a bead on his K-Locks within 5 minutes of me, so maybe we hit some unseen bead breaker?? I would buy the MattO rims again in a heartbeat. I did have minor air leakage though, and the slime stopped it completely. It takes a whole gallon though to do all 6 tires.
