I have a set of channel tracks on my 2015 Argo frontier 8x8. I really like the tracks as far as crossing swampy areas and in the woods. But I have found in tall grass I don't like them at all. After diving the Argo 3/4 mile in tall grass or even after making a trail in the grass and driving the same trail I had made. I would have grass building up round the axles. The most grass build up around the rear axle not as bad on the front some on the middle four axles. It is a pain to remove the grass from the axles, you need a utility knife or sharp knife to cut the grass off the axles after it balls up around them. What I see is the grass getting between the metal (channels) on the track and the tire then tears the grass from the ground. Then ends up falls down between the tire and track then carried round the inside of the track and dumped onto the axles and rolled up tight on the axle. Had to clean grass off axles every time I used it in grassy trail or in tall grass. Here's some pictures. I love the channel tracks every where else but in that grass.
Tall Grass and Channel Tracks are bad news
