IMG_2171.jpgIMG_2169.jpgMy tracks came yesterday and the timing could have not been better as I had just finished up getting all the accessories on the Frontier. The Adairs look impressive to say the least and the components used appear to be heavy duty (grousers, thick belting, and) hardware. I first installed the mud/snow flaps on the rear and then installed the tracks easily with the help of one heavy duty ratchet strap to join the hinges together after deflating the front and rear tires. I had already indexed the tires and I put the Argo recommended 5,6,6,7 psi from front to back. Adair says 5-6 psi in the tires is a good range. When I looked at the completed machine the name "Mean Joe Green" immediately popped into my head!
The most dramatic thing I noticed and was expecting was how much higher the machine set. I took a bunch of notes on the ground clearance of my Conquest with the Chanel tracks and the Frontier before and after installing the Adairs. I like nerding out on things like that and some of you may appreciate this as well but here are the numbers:
Frontier with 24x10x8 tires @ 5 psi:
Front chain/sprocket chanel 7 1/2"
Front center belly 9"
Rear chain/sprocket chanel 9"
Rear center belly 10 3/4"
Frontier with Adair Pro Series w/metal cleat winter kit (tires 5,6,6,7 psi):
Front chain/sprocket chanel 9 1/4"
Front center belly 10 3/4"
Rear chain/sprocket chanel 10 1/8"
Rear center belly 12"
Conquest 22" Chanel tracks with 22x11x8 Carlisle Stryker (tires averaging 6 psi):
Front center belly 8 1/4"
Rear chain/sprocket chanel 7 3/4"
Rear center belly 8 1/2"
The Stryker tires on the Conquest run large and are very close to the diameter of the 24" Frontier tires. The things that I attribute to the differences in ground clearance are the lower tub designs and the grousers on the Adair tracks are much taller. Ground clearance isn't the end all factor as I have ran my Conquest in VERY deep snow dragging the belly and pushing a huge wave of snow in front of me with little difficulty, but it will be interesting to see the difference it does make.
The funny thing is I have to pull the Frontier into my garage now because it doesn't clear the door opening reversing in and barely clears pulling in. My drive way is steep and this causes a lot of the issue backing in.
One other thing I noted was the width of the two machines with their track on. The Conquest is 77" wide with 2.5 spacers/tuners and the Frontier is 75" wide with the 18 1/2" Pro Series with my reversible rims reversed/flipped.
