Needed something to do during the pandemic this winter so I decided to make some tracks. They're something I've wanted for a few years now. I take care of a small parking lot adjacent to a swamp and got tired of getting stuck with just tires as I pushed snow into the swamp. Defidently a bit of a learning curve to do, and was a little overconfident at the start. I managed to finish them right as winter is ending, so the real test will have to wait until January next year but at least hopefully I will be ready.got cocky with the tire guides and they bent almost instantly. Added in a reinforcement to make them stronger. No I know why they are like that on other designs
DIY mini snow cat tracks
New tire guide design worked great but I only used 1 row of bolts to attach the grousers to the belts so on turns they decided to pivot on the bolts and drive themselves up the tires. Again found out the hard way why other designs use 2 or more bolts per side of the grouser. Marked , drilled and bolted a second row. The offset of the bolts is to give them the most distance appart to stop the twist. They hold together good now but I have only tested them on bare gravel parking lot and packed sled trails so far. They are definitely agressive and dig into the gravel so they should work well when snow flies next year
Cant wait to see how they do in the mud, musket and water!
Tec specs:
14.5" wide total
14" grouser from 1×1/8 angle with chamfered ends for turning
2.5" belt width
5" grouser spacing
5/16 main bolt and lock nut
1/4 secondary bolt to stop the track from twisting
1×1/8 flat steel for tire guides
33 grousers per sideAttached Files
not a critiqu but you may want to bend those tire guides a bit more at the top and away from the tires. Tires flex on these machines due to skid steering anddistort even with tracks on. I maybe wrong but just to be on the safe side. also I have had tracks on and gotten a large stick caught in between the tracks and tire, also causing distortion.
the pic of the tracks on the machine, look at the guides that are at the rear tire the one that is just at the tire not musch flare/ it could be me and I'm looking at a 2D pic. they do look aggressive and should provide good traction.
Probably around 100 hours give or take but a bunch of that was messing around with the design and going back to fix problems. Also did all the work with a hand drill, angle grinder, and a mini stick welder. A chop saw and a drill press would have shaved a few hours off for sure! Materials were around $1000. Bolts aren't cheap!
Took the argo out in the Bush today to find some untouched snow in the shade. I jumped out and sunk past my knee! Chainsaw in the picture has a 14" bar and it is not at the ground. So the tracks worked well to keep me on top of the snow. It was pretty crusty and had harder spots and softer spots from the thawing and freezing we are having right now. Now I realy cant wait to see how they do in fresh fallen snow next year!Attached Files
