I just purchased a new Frontier 650 , 8X8 with reversible rims and Adair 14 inch tracks. I was wondering how most guys are running the wheels with the tracks on. Dished out which makes the machine wider or dished in making the overall machine narrower. It looks like they can be run either way. I will only be running the tracks in the snow. Thanks
Track Width
Fishgo, something to note, when you install your tracks, the inner hinge bolt , you want to install that with the threads and the nylock lock nut closest to the tub. This way if the bolt were to come loose , when it walks off it doesn’t damage your tub. It usually never happens but it’s a detail on installation to be aware of. Good luck with new machine.
The Adairs are designed so they can be run without extensions and most guys run them in, if you get the winter kit you may wish to run rims out depending on the winter kit you get.Originally posted by fishgo28 View PostI just purchased a new Frontier 650 , 8X8 with reversible rims and Adair 14 inch tracks. I was wondering how most guys are running the wheels with the tracks on. Dished out which makes the machine wider or dished in making the overall machine narrower. It looks like they can be run either way. I will only be running the tracks in the snow. Thankssigpic
You can run Adair's with just a 5/16" spacer on each wheel and not have an issue. As has already been stated your machine will be narrower without reversing the rims. How ever I would like to point out that under certain extreme conditions (I have been in a lot of them) The tracks can twist on the tires and come close to or bite the tub and damage your tub. For this reason if I have an options I would always run the tracks with the wheels reversed even through this is a limitation on tight trails. I might want to add the reversed rims will make you machine more stable.Originally posted by fishgo28 View PostI just purchased a new Frontier 650 , 8X8 with reversible rims and Adair 14 inch tracks. I was wondering how most guys are running the wheels with the tracks on. Dished out which makes the machine wider or dished in making the overall machine narrower. It looks like they can be run either way. I will only be running the tracks in the snow. Thanks
Agree with Dan, additional clearance to tub is better. Wider stance is better on firm ground or soft, or water.Originally posted by mightymaxIV View PostYou can run Adair's with just a 5/16" spacer on each wheel and not have an issue. As has already been stated your machine will be narrower without reversing the rims. How ever I would like to point out that under certain extreme conditions (I have been in a lot of them) The tracks can twist on the tires and come close to or bite the tub and damage your tub. For this reason if I have an options I would always run the tracks with the wheels reversed even through this is a limitation on tight trails. I might want to add the reversed rims will make you machine more stable.
