No worries, I figured it would just be a matter of time until you would see this. I've been thinking of doing the same thing and obviously one of the most expensive part would the snowmobile tracks. I know you suggested finding some used tracks. Are you just going to splice different tracks together?? If not, where the hell do you find 3 used tracks with the same pattern for a decent price that would make a project like this worth it!?
BC, Not too far from me is Snowline Sports Snowline Sports
Check out the pic of their track inventory. I will be checking with them, before winter to see what they have.
Also another source is conveyor belt manufacturers, many have very interesting patterns, some with raised chevron style patterns that swim. The only downsize is most don't have lateral stiffeners and flex (curl) up outside the tire width. But if you install lateral cleats they should work out OK.
I've sourced out one company that makes what I want but you need to buy it in 100 ft. rolls, so maybe a couple of us guys will work together and split the costs. I will update this thread as the fall approaches.
if you are on the cheep for convayor belting go to your local gravel pit that is where i work and we throw the stuff away some times. ask for used belting and they might sell it or give it to you. also there ie a product called flexco this is what holds a convayer belt together it will work for one of the splices on your snowmobile trax you will need the argo splice for the pin but it will save you125$. I looked at the argo dealers supper tracks for the centaurs and thats what they use convaer belt with angel metal bolted on. it is also what they use for the plastic extention kit.
I too am looking into making a homemade set for an 8 wheeler, but i think the cost will be higher than what first thought, lets say im building a set like BW6's friends for a 6x6, he has 22 guides/side thats 88 guides for the set at $4 each thats $352 just for the guides then if each splice kit is $125 and you need 4 then thats another $500 then i still need to add taxes, then buy some old sled tracks along with hardware for the guides etc. I was thinking of just using what they use to join conveyor together for joining the tracks and making my own guides from galvanized steel like the escargo tracks have, i have a metal bender at work so that would be no problem but still have to think of a good guide design and do some resarch. Any thoughts? Input?
"Argo 8x8's only" type of guy
"old school Argo expert"
Hey Guys, great to see those tracks. I really need a set for my Bigfoot. I sold my plastic tracks this spring. Hope the video will be available. I am in the Ottawa Valley. Need to do something asap.. Thanks, Mark..
hi! these tracks are made of conveyor belt type of material..... the chain part is the same as tire chains for a car or pick up truck, (no cable)
they hold on the rounded tires very well, you could make them at home too, not spending crazy money for tracks that wear out faster than you think. thses are very replaceable parts too
This Year, i can't wait until it REALLY snows!!
goin to be doin some test bending for guides on the shop iron worker this sunday, material is 1" galvanized tube(conduit) cut in half, ill let ya know how i make out, im hopin if it works that i could keep the cost around $0.60 per guide with hardware and backing plate.
