vampires, asx vampire combo
  • smokin cigarettes
    replied
    Originally posted by fulleraviation View Post
    Got to test the ASX tires today. We just had 12" of rain in the last 3 days. The tires do present a softer ride, and I settled for about 3 psi. Acceleration seems the same with the 18HP vanguard as with the stock tires. In the mud, these tires are incredible. In the water they leave alot to be desired. On single track that is flooded, I found it very hard to control while floating. I found myself drifting into trees and bushes. I never had that problem with the Goodyears. Testing in the pond with the tires in the forward position showed 1.3mph...Funny the Goodyears were 3.1mph.
    I went home and flipped the tires to run backwards like we usually run. Not much better, but 1.7mph at 3,500rpm. Higher RPM's seem to throw water into the hull from the rear.
    Still waiting on the wheel spacers. I will try some more testing with spacers. I am thinking that I will probably fit two Goodyears on the rear to try and gain control in the water.
    Thanks for the feedback on them. I will be interested to hear how they do with the rawhide combo.
  • fulleraviation
    replied
  • mudbug3
    replied
    ( QUOTE ) " I'll get some video as soon as I head up there again "
    jpswift1
    That sure sounds good ! Can,t wait to see the video when you post it on the forum.
  • jpswift1
    replied
    Well guys, I might just have to take my Hustler through that huge mudhole I mentioned before. It is known all around the town as the mud bog that nobody can get through (because most folks ride quads around here and always get stuck in it when they try to cross). I was able to work my Max II through there once, but I really had to rock it back and forth and it was quite a job, but I did make it. I think the Hustler on 26" ASX's would have to put much less effort forth. I'll get some video as soon as I head up there again.
  • mudbug3
    replied
    jpswift1,
    MightymaxIV and myself are both "chomping at the bit " to see how well six ASX tires perform on your Hustler Bigfoot , in some really SERIOUs mud!!
  • jpswift1
    replied
    Thanks! I've had mine on my Hustler 980 BIGFOOT since last summer, but haven't tried them in any serious mud yet. That's going to change later this month when I take it on some trails near my place that swallow huge full size lifted trucks with 1 ton running gear and 44" tires. There is plenty of space on Hustlers for these wide tires and they don't even come close to rubbing. There is no need for wheel spacers either. I'll be sure to have some videos of serious mud action coming soon.
  • toni5091
    replied
    spacers
    jpswift1, Have you had your asx tires on your machine for awhile do they rub or do you have spacers also? Would like to see video of these in mud I've seen the creek run looked good
  • jpswift1
    replied
    They sure do look great! You're going to love the performance of these tires.......it's the difference between night and day. Keep us updated.
  • Roger S
    replied
    That looks like some major rubberage you got there.. must be exciting for you guys who are trying this.
  • fulleraviation
    replied
    Well, I got the tires mounted. They bolt on with what looks like ok clearance without spacers. I only test drove it arround the yard in the rain, so better info will follow. I should have spacers by the end of the week. I think Dan says that the tires can rub on the tub when turning, and is the reason for the spacers.
    Later,
    Rut
  • mudbug3
    replied
    My prediction is this:
    The ASX tires won,t swim as fast as the Terra tires ,and surely not as fast as the new 25 inch , Frontier tires, but for sure , they,ll be faster in the water than the Vampire TSL tires.
  • boncrshr
    replied
    Pretty excited to hear the results.....I don't have a prediction about the water speed...but I know how the mudding test is going to go!
  • jpswift1
    replied
    Glad to hear your tires made it to you.......these things are no joke! I remember when mine were shipped to me. I counldn't believe the difference between them and the stock Goodyears on my Hustler 980. Once you take them for the first ride you'll be hooked. Keep us updated.
  • fulleraviation
    replied
    Tires arrived and man do they look impressive. Still waiting on the wheel spacers and should have tires mounted tomorrow. I can feel a couple of sick days comming on from work.
  • fulleraviation
    replied
    WOW!!!! Got a call from the trucklines. My new ASX tires will be here tomorrow!!!!! Direct from Interco!!! Howd they do that
    Rut
