ok i finally found some tires they are the powertrac II tires made by carlisle i heard they swim pretty good also but my question to you guys is they come in a size 21-11.00X8 will these fit on an 8X8 rim they look pretty wide i usually run a 22-11.00X8 tire
powertrac II tires
yep they fit if you are running 22x11 x8 robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
Robbie is right, those will fit just fine. You won't have any trouble at all fitting those on an 8x8 rim. I've seen it done plenty of times without any problems at all."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
