I have a MAX IV that I need to replace 2 tires on. They are Goodyear Rawhide 22 x 11 x 8..Does anyone know of a source in SE Michigan or a store that sells them on-line ? I keep losing air pressure and can't find any leaks in them even using soapy water. Also, where are the drain plugs located in the tub ? Thanks for any help from another old new guy
tire source ?
for those tires you will have to call rec to get them . goodyear is not haveing them made any moore . as for your pluggs they are at the rear of the tubb in the chain chanels robbieOriginally posted by jeepfxr View PostI have a MAX IV that I need to replace 2 tires on. They are Goodyear Rawhide 22 x 11 x 8..Does anyone know of a source in SE Michigan or a store that sells them on-line ? I keep losing air pressure and can't find any leaks in them even using soapy water. Also, where are the drain plugs located in the tub ? Thanks for any help from another old new guy1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
Goodyear 21's
Thanks for the replies. I guess that I better concentrate on finding out why the tires I have are losing pressure before I give up on them. What would be involved in going to 22's other than a lot of money ? Amphiman, do you have some for sale ? Thanks again, what a great group of guys you are. Jeepfxr
carlise has them jest about any tire dealor can get them robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
Hey Buddy, why don't you just install tubes. I've punctured a few of my tires and they were actually too bad to fix and yet I've installed tubes and have been motoring for quite some time with no problems.Originally posted by jeepfxr View PostI have a MAX IV that I need to replace 2 tires on. They are Goodyear Rawhide 22 x 11 x 8..Does anyone know of a source in SE Michigan or a store that sells them on-line ? I keep losing air pressure and can't find any leaks in them even using soapy water. Also, where are the drain plugs located in the tub ? Thanks for any help from another old new guy
that works but at 1 to 2 3 lbs they spin and cut the tubes robbie this is a on line ste with good prices Motorcycle Tires, ATV Tires, Lawn Tires, Carlisle TiresOriginally posted by Mr_Riveter View PostHey Buddy, why don't you just install tubes. I've punctured a few of my tires and they were actually too bad to fix and yet I've installed tubes and have been motoring for quite some time with no problems.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
while checking your tires for leaks with soapy water, a lot of people fail to look at the valve stems. the cores could be loose, be tight and leaking (dirt holding them slightly open) or the stems themselves could be dry rotted.
just a few ideas before you buy new tiresA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
