Are the old Attex hubs wort anything? I was thinking of using them to make adapters for using golf cart rims but I dont want to cut up something that someone else could use.
Attex hubs?
They may be to someone. But most people are probably in same boat with old hubs needing newer updated tires making the old 3 bolt hubs worthless without adapters. It would be pretty easy to find some thick 1 " tubing to make your own "newer" style hubs though.Originally posted by birddog1148 View PostAre the old Attex hubs wort anything? I was thinking of using them to make adapters for using golf cart rims but I dont want to cut up something that someone else could use.
You might want to check with Jpswift1, he is using 4 bolt wheels on his new racer and I think he might already have a template for 3 bolt to 4 bolt.Originally posted by birddog1148 View PostWell I printed that template off of here and the 3 bolt hole line up. I guess the next thing I need to do is build a cutting adaptor for the torch to cut true circles and modify the template for a 4 bolt pattern and try it.
Not sure but at least a couple of the holes from the 4 and 5 pattern would probably be too close together or overlap. But anyways, you would have to remove and re-install the studs since the unused studs would prevent you from putting the rim on, and if you use bolts they won't quite center right, and are a @#%@$% pain in the butt to install a rim with anyways.Originally posted by birddog1148 View PostThanks Mike!
I cant help but wonder if a guy could make a set of adaptors using both templates and be able to run 4 OR 5 lug rims on the same adaptor.Attex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
