attex tires
  • attex tires
    Hey guys,i have a broken valve stem on my attex tire,its the tire with the small center,is there any way to replace the stem,thanks,john.
    Hey tractorguy,
    You can push a new one in backwards. It takes a bit of messing around though. I used good ole wd40 as a lube. I have in the past use dish soapy water too. Use a screw driver that isnt to sharp and push it in and work it around. When you cant reach it anymore on the side that is inwards, I spun it with a pair of pliers while I was pushing in.
      tires
      Thank you larry that is just what i wanted to hear,i will play with it tomorrow night,thanks again,john.
        tire repair....
        don't forget to clean/sand the area, hole, well too. i usually paint the rim too before installing the stem... better sealing chances.,
          tire
          Good idea,i only want to do it once,i will make sure it's clean and painted,thanks for the help,john.
